06-02-2020
10:28
16:52
06-02-2020
10:28
16:52
I have had my Fitbit for about 6 months and three days ago it died, so I started charging it on my usual Fitbit charger. I leave it there for the night, properly plugged in, but when I wake up it has not charged and won’t turn on. Tried 3 other chargers and a couple other charging blocks but nothing is working. My sister’s Fitbit is charging well on the same charger. It is not synced to my phone and will not sync so I can’t change the clock face (I’ve tried) and I cant restart it because it has no power and the charger is preventing me from doing so while it is “charging”.
Hi there @mgnlmn, welcome to the Community Forums. Thanks for the details provided about your Versa 2's behavior and for taking the time to troubleshoot it prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. Thanks for letting me know that the charger is working fine as it did work with your sister's Fitbit. So, I recommend that you follow these steps (or please confirm that you've followed them as described below):
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best AnswerLikewise, steps above don't work for me either. Watch is 6 months old. About to launch a warranty claim. It's been dead for a month! Same troubleshooting as original poster to no avail.
There isn’t a button on the back?
I can put my finger over the sensor?
My versa 2 died yesterday, it’s 10months old. Not like battery dead, I had no notification of a low battery (I usually get an email), I just noticed it was black.
I had it on charge all last night, woke up and it was still the same, I checked to see if I’d forgotten to plug it in but I had! I took it off, put it on again and for a moment it seemed to work charging, gave it 10 mins and back to black screen.
Now when I press the side button sometimes a picture of the battery with an exclamation comes up.
