12-08-2020
05:34
08:59
12-08-2020
05:34
08:59
My Versa 2 is totally blocked. The fitbit logo appears on the screen and it doesn't turn off or restarts. It doesn't sync either with my android phone.
What can I do?
12-08-2020 09:03 - edited 10-08-2023 04:36
Hi there @MBViana, welcome to the Community Forums. Thanks for already troubleshooting your Versa 2.
It seems that your watch is asking you to pair it to your Fitbit app again. As per the description of your post it looks like you've unpaired the Versa 2 only from the Fitbit app but not from the phone's Bluetooth settings. Note that the Fitbit logo usually appears when you've performed a factory reset without first unpairing the watch from the phone's Bluetooth settings.
That being said, please try the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer12-08-2020 09:03 - edited 10-08-2023 04:36
