02-26-2021
03:28
11:48
02-26-2021
03:28
11:48
I tried to update my versa 2 a couple of days ago but it seemed to crash mid-update. I've tried to follow the reset guidance as seen on other posts on the community but it won't even do that. I've let the watch run out of battery twice now and recharge in the hope it would naturally resolve but it is still just frozen on the logo screen. Really frustrating and disappointing given the versa is less than a year old.
02-26-2021 11:51 - edited 07-05-2024 13:08
Hi there @SallyMay, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand how frustrating this can be.
In addition to the steps you've done so far, please try the following:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
Best Answer02-26-2021 04:41
02-26-2021 04:41
Probably best to contact Fitbit Support directly. They may be able to help you.
Best Answer02-26-2021 11:51 - edited 07-05-2024 13:08
Hope that helps.
Best Answer02-27-2021 02:55
02-27-2021 02:55
Hi,
Thanks but I have tried this and the fitbit is still just jammed on the fitbit logo screen. It still won't reboot either. Is there a chat function to be able to speak to support?
02-27-2021 03:20 - edited 12-08-2023 01:43
@SallyMay Thanks for following the steps provided to you.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of the steps you've done, this way you could also avoid repeating yourself one more time.
We hope your issue is solved soon.
