03-29-2021
22:01
07:04
03-29-2021
22:01
07:04
My versa 2 keep showing the fitbit logo for 5 seconds then turns black than back again. I have tried pressing the side button with no luck
Hi there, @Rwobadia. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the step you've performed so far, please try the following:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
@Rwobadia Thanks for following the suggestions I've provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
