04-19-2021
12:00
13:05
04-19-2021
12:00
13:05
My fitibit is stuck on the logo screen. I have followed many others on the forum for resetting and it still only shows the logo. There isn't any vibrations or anything.
That sucks! 2 years? That's good, I'm just over a year!! I though I was looking at having to buy a new one. Thanks!!
12:33
13:04
04-19-2021
12:33
13:04
I did purchase the optional insurance since I had so much trouble with the
Charge 2.
Moderator Edit: Personal info removed
Hi there, @Lbologna3 and @Jwiens7145. Thanks for trying to troubleshoot the issue with your Versa 2 smartwatches before reaching out. We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
@Lbologna3 I'm glad to hear your replacement is on its way.
@Jwiens7145 In addition to the steps you've performed so far, please try the following:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
13:17
13:54
04-19-2021
13:17
13:54
I am hoping it is on the way. I have had no correspondence from Fitbit
since I shipped it on the 12th of April.
Best AnswerI did that and I'm back to having no screen and it won't pair. Doesn't see it when searching
Best Answer04-20-2021 07:48 - last edited on 05-03-2021 16:58 by LiliyaFitbit
Call Fitbit to see if you still have coverage under the warranty, or you
can do a chat with them on line
Best AnswerJust wondering what I can do to get a real response from the issue I have with my Versa 2. I mailed it back April 14th around 5pm with their parsel post label. The post office checked it in around 6:30pm. It stayed there until the 16th where it was transferred to FedEx. I cannot get any information on it's whereabouts and only get a programmed response when I email them. It's been over two and a half weeks and I have no information on where it is and when the replacement can get to me. They only say they will mail one out 5 days after they receive it.
