09-27-2022
13:58
10:25
09-27-2022
13:58
10:25
My versa 2 was needing a update and it froze half way through and it stuck on the Fitbit logo
09-27-2022 14:14
09-27-2022 14:14
Same thing happening to me! Hopefully we will
receive guidance from fitbit!
09-27-2022 15:24
09-28-2022 10:28
09-28-2022 10:28
Hi there, @sandyduarte @kamilleon. Welcome to the Community Forums. Thanks for the details provided in your posts about the issue with your Versa 2 devices.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues while updating your Fitbit devices, see Why can't I update my Fitbit device?
Hello, @SmirkingSoul. Welcome on board. I understand how you must be feeling. Nevertheless, I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around!
Best Answer09-28-2022 12:31
09-28-2022 12:31
I'm still having the same issue it started the setup and installing but it is stuck on installing after all the steps below reply.
Best Answer09-28-2022 12:43
09-28-2022 12:43
Hello, @busall66. Welcome to the Community Forums. Thanks for following the tips and recommendations I've provided above.
By any chance, are you an Android user? If so, please know that since you're an Android user you can't use MobileTrack in addition to a Fitbit device. For more information about MobileTrack, see How do I use Fitbit MobileTrack?
If you have MobileTrack linked to your Fitbit account you'll need to remove it in order to set up the Fitbit device and get back on track. For instructions, see How do I set up my Fitbit device?
Once the above has been attempted, please try one more time to update your Fitbit device.
Hope that helps.
Best Answer09-28-2022 13:05
09-28-2022 13:05
I have done everything mentioned. I tried to reach support however when I click on link, it is blank! Very disappointed that so many of us are having the same issue. I am lost without my Fitbit!
Best Answer09-28-2022 15:42
09-28-2022 15:42
I’m also having the same issues. I’ve restarted phone and watch, disconnected Bluetooth, exited fit bit app. Nothing is working. I’m thinking of switching to Apple watch seeing that this is a huge trend with minimal helpful support
09-28-2022 15:57
09-28-2022 15:57
Mine will be here Tuesday. I’ve been very loyal to Fitbit and it has really motivated me however seeing so many of us going through the same thing and no resolution leaves me a bit salty.
Best Answer09-29-2022 00:10
09-29-2022 00:10
Best Answer09-29-2022 07:55 - edited 03-15-2024 06:27
Hi there, @kamilleon @busall66 @Annajkern (Welcome on board!). I appreciate you had followed the tips and recommendations provided above. We‘re taking your comments and sentiments in regards to our products into consideration.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Best Answer09-29-2022 22:48
09-29-2022 22:48
Best Answer10-01-2022 08:37
10-01-2022 08:37
Me too!!
Best Answer10-01-2022 18:43
10-01-2022 18:43
I’m having this same issue and have tried all the troubleshooting tips suggested. Still stuck on the logo screen.
