10-22-2022
12:50
13:13
10-22-2022
12:50
13:13
The Versa 2 is synced but the watch face just has the fitbit logo, and can't swipe. No watch face or anything, just the logo.
10-24-2022 13:14 - edited 08-04-2023 04:28
Hi there, @Caverbob. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. @SunsetRunner Thanks for your help!
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer10-22-2022 15:05
10-22-2022 15:05
Can you try changing the watch face as long as it is communicating with the app?
Also, some had luck letting the battery completely drain when it is in this state, then charging it and changing the watch face.
Good luck!
