10-13-2023
05:48
10:44
10-13-2023
05:48
10:44
I just noticed my Fitbit was showing the logo. I assumed it just randomly crashed, but it keeps continuously turning off, on, showing the logo a couple of seconds, and off again, repeat. Is there anything I can do to fix this? I tried going to the support page, but it no longer exists.
Edit: it just showed green bars on the screen and the logo got kinda dim and flickering with occasional green stripe across the screen. It eventually showed the no battery left even though I charged it less than 20 hours ago. Put it to the charger and it continues to bootloop.
10-18-2023
15:40
15:33
ManuFitbit
10-18-2023
15:40
15:33
ManuFitbit
I'm having the same problem as well!
I just moved mine to Google, Roger, thinking the issue may resolve itself. It did not.
I agree Dave. Planned obsolescence makes sense as the Versa2 doesn't even show up on the Versa help landing page.
10-18-2023 17:10
10-18-2023 17:10
@PegT2023 What? Here's what I see.
Support for Versa 3, Versa 2, Versa, and Versa Lite Smartwatches
10-18-2023 22:13
10-18-2023 22:13
I am using versa 3 and the same logo stuck issue popped up 2 days ago. Customer support could not resolve it. Warranty doesn't cover. Fitbit wants its customers to buy new devices with 35% discount. Junk devices that last little over warranty period! Looks more like a scam!!
10-19-2023 00:37
10-19-2023 00:37
Same problem here. Several days of being stuck on the clock screen unable to swipe. Tried holding the side button down for all kinds of time periods to no avail and today I have the intermittent logo screen, so currently Fitbit completely useless.
Will try that convoluted reset later, but not confident.
10-19-2023 01:48 - edited 10-19-2023 01:51
@DaveMG if you're in Europe you have extra protection regarding warranty. They can say 2 years, but according to EU law it'll be longer depending on the type of product
Best Answer10-19-2023 01:50
10-19-2023 01:50
No. It showed the logo again for a bit, turned green, and is doing nothing again sadly.
Best Answer10-19-2023 02:20
10-19-2023 02:20
10-20-2023 01:03
10-20-2023 01:03
Same issue here. Totally non responsive even though its fully charged. Problem only starred after I moved to Google account. Wonder does this have anything to do with it?
10-29-2023 05:12
10-29-2023 05:12
10-29-2023 06:08
10-29-2023 06:08
10-29-2023 06:11
10-29-2023 06:11
A free replacement? 50% off? They only offered me 35% off. How did you manage to get this? Is your device also out of warranty?
Mine boots again, but the touchscreen and vibration don't work anymore 😔.
10-29-2023 07:48
10-29-2023 07:48
10-31-2023 13:06
10-31-2023 13:06
I have the same issue. How do I solve this?
Best Answer10-31-2023 13:07 - edited 10-31-2023 13:11
10-31-2023 13:27
10-31-2023 13:27
I don't really want to buy a new one. The inside/wrist side is a bit worn, but the screen side seems to be fine, not damaged. No idea why it stopped. It seems like everyone in the issue-thread is talking about planned obsolescence
