08-15-2023
04:32
05:49
08-15-2023
04:32
05:49
Versa 2 stuck on logo screen
08-15-2023 05:50
08-15-2023 05:50
Hi there, @gdolt. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. So to better assist you, please confirm that you've tried all the steps listed below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
Best Answer08-15-2023 09:32
08-15-2023 09:32
Best Answer08-15-2023 14:09
08-15-2023 14:09
I am in the same boat. Tried all the steps with no change.
Best Answer08-15-2023 20:58
08-15-2023 20:58
Same. Happeded midday today. Nothing is working.
Best Answer08-15-2023 23:47
08-15-2023 23:47
Hi, I had this and resolved it by changing the watchface design using the FItbit App. Just choose any........ No idea why it worked but it did.
Hope it helps.
08-16-2023 10:40
08-16-2023 10:40
I wish that I had seen this BEFORE I removed my watch from the ap. Now I can't change the clock face. So frustrating.
Best Answer08-16-2023 10:52
08-16-2023 10:52
Hi everyone, thanks for the heads up.
Please note that we are taking your comments into consideration. In order to get you guys back on track as soon as possible, I'd suggest getting in touch with our Customer Support team, it is the fastest way to get a resolution as suitable as here. For those that haven't made any troubleshooting, please do not unpair your Fitbit device or uninstall the Fitbit app because you might not be able to pair the device again.
Best Answer08-16-2023 11:12
08-16-2023 11:12
This is very unfortunate since that is exactly what I was instructed to do. So, what now?
