11-06-2021
14:19
10:41
11-06-2021
14:19
10:41
Greetings,
my wife’s versa 2 suddenly stopped working. The FitBit app sees it but can’t sync or update it. I’ve removed and repaired it twice.
when I try to reset it, the FitBit logo displays like normal but after a minute or so it displays “Data not cleared Sync and try again”
We’re stuck at this point.
11-08-2021 10:43 - edited 09-14-2023 09:45
Hi there, @GBradburn. Welcome to the Community Forums. Thanks for trying to troubleshoot your wife's Versa 2 before reaching out.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing the Fitbit device from the phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with her Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
