12-12-2020
11:53
06:21
JuanJoFitbit
12-12-2020
11:53
06:21
JuanJoFitbit
Versa 2 Stopped Synching via WiFi and Reset
I began having some issues with my Versa 2 about a week ago. I noticed that it shut off completely and wouldn't synch with my iPhone. I brought it back home and put it in the charger to re-set it. I thought all was well. I then used it the next day and it shut off again.
I connected the Versa to the charger again and attempted a factory reset. Then completed the reset process over Bluetooth because the watch / phone didn't connect to the 5g Wifi network in my apartment. The watch reset. I attempted to download an update. It was incredibly slow over Bluetooth.
Now I can't remove the watch at all from the charger. Sometimes the screen flashes on. But it indicates that the battery is at 0%.
12-14-2020 06:21
12-14-2020 06:21
Hi @notdaveng, it's great to see you in our Fitbit Community. I totally understand how you feel about the syncing and screen issues that your Versa 2 has experienced. By the way, thank you for trying to get this issue resolved before contacting our forums.
In order to avoid providing the same information, let me know how the factory reset was performed. In the meantime, try the troubleshooting steps that are listed in this help article. After this, charge your watch for 2-3 hours and see if it turns on properly.
In case the syncing issue persists, follow the steps listed in this help article. Finally, monitor your watch during the next 24 hours and see if the issues get fixed.
Keep me posted on the outcome.
12-14-2020 07:45
12-14-2020 07:45
Hi @JuanJoFitbit. I've attempted those steps prior to posting in the forum. I confirm that I have also factory reset my watch without any success.
05:03
14:07
12-16-2020
05:03
14:07
Hi @notdaveng, thank you for trying the steps previously shared. Please let me know if you performed the factory reset as advised below:
After this, set up your watch from scratch and see if it works properly.
Let me know how it goes.
