01-16-2020
16:34
04:35
JuanJoFitbit
01-16-2020
16:34
04:35
JuanJoFitbit
I am having the same problem others have reported. I have had the Versa 2 for 4 days now and it has disconnected from Bluetooth every day. I have reinstalled the app, have all-day sync turned on, my phone is compatible with the list. I have restarted tons of times. Removed the device and readded it etc...
I have to go through the setup process again, usually many times until my phone finds the device then it works for a few hours and I have to go through it all over again. The Fitbit app on the phone reports that it can't find the device and I go back down the rabbit hole.
I really love the Versa 2 when it's working, but obviously I will need to return it if this isn't fixed soon. I simply can't be expected to spend this much time with it every day. Upgrading from my Charge 2 the finally died and it never disconnected from Bluetooth.
Fitbit please fix!!! I want to keep my Versa!
01-22-2020 04:35
01-22-2020 04:35
@Perpet, I'm sorry for the late response. However, it's great to see you in our Fitbit forums.
Regarding the connection issue that your Fitbit Versa 2 is experiencing with your phone's Bluetooth, I appreciate the time spent trying to get this issue resolved before contacting our forums.
I was able to get in touch with our Support team and was told that they assisted you via chat after you started this thread. I would like to follow up and would like to know if the issue got fixed.
Looking forward to your response.
Best Answer01-22-2020 09:20
01-22-2020 09:20
Best Answer01-22-2020 12:47 - edited 01-22-2020 12:48
I have the same problem with a Nokia 8.1. Sometimes they sync well for a couple of hours and then... the devices seem to forget that they are connected... returned to store and tomorrow i'll get a new one but i'm afraid it will not be a solution. With my Charge 3 there never was a problem...
