02-16-2022
09:04
12:29
02-16-2022
09:04
12:29
For the last week or so, I have noticed that I wasn't able to move between screens or scroll through stats on the front screen. After searching online, I saw I had to re-start the watch and that works. However, it is happening multiples times per day. It's 11 AM now and I have had to re-start 3 times already. Why is this happening? I had a blaze for 2 years prior to my Versa 2, which I've also had for almost 2 years now, and never had this problem before the last week or 2. 😑
02-16-2022 11:53
02-16-2022 11:53
Hi @EricawithaC - have you tried changing the clock face in case it is having problems. Also check whether the watch is syncing in the Fitbit App easily.
Best Answer02-16-2022 15:04
02-16-2022 15:04
I have this with mine but every 4/6weeks. I report to fitbit and they tell me to restart. I restart and they say there is no issue. It's a joke. An obviously faulty watch which they have no intention on sorting. I won't be purchasing another fitbit
02-16-2022 16:24
02-16-2022 16:24
Starting having issues with mine about 2weeks ago as well.
02-16-2022 22:16
02-16-2022 22:16
Don't bother contacting them, they won't do anything. Each time this happens, I contact them, they say that because the face then works there is no issue and then to contact them when it happens again. I do this, they give me the same 'advice' and nothing.
I asked to speak to a manager and the operative I spoke to didn't action my request. I ended up leaving the chat because of how frustrating and unhelpful they are.
I won't be purchasing another Fitbit after this.
Best Answer02-16-2022 22:25
02-16-2022 22:34
02-16-2022 22:34
Thanks for this! I do check for updates and I am in challenges with my friends so I sync multiple times a day so I don't think it's that.
I have the original watch face too and still have issues.
It's not fit for purpose.
02-16-2022 22:54
02-16-2022 22:54
@dpartner - what phone do you have? Some phones have peculiarities with certain versions of the Fitbit App or just have problems. It is rare that I have any syncing problem on Android S9+.
Often there are other simpler solutions which don't need a restart, such as turning off the Bluetooth for a few minutes, or logging out and back in to refresh the connection.
If you install the SimpleCheckUp app on the watch it will tell you next time when you last synced and if the watch can connect to the Fitbit App directly on the watch, so you will have more information as to what the cause is.
02-16-2022 23:13
02-16-2022 23:13
iPhone 11.
Mine requires a restart as the screen goes black and doesn't respond.
It's definitely a watch issue and not a syncing issue.
thanks for your help though.
02-16-2022 23:18
02-16-2022 23:18
@dpartner - thanks for the clarification.
When the watch goes blank, does a double tap and swipe left wake up the display?
Presumably it is still syncing even if the display is blank?
When the display is blank and you put it on the charger does it display anything, immediately, or after a few minutes if you double tap it?
Best Answer02-17-2022 00:07
02-17-2022 00:07
When it goes blank, nothing works. Double tapping, side button, swipe down from the top, nothing.
Have to complete a restart for it to do anything.
02-17-2022 00:08
02-17-2022 00:08
It won't recognise the charger when screen blank and when a restart is completed, the battery has drained to 20/30%
02-17-2022 00:57
02-17-2022 00:57
@dpartner - thank you for the interesting behaviour and thorough feedback which is really weird .
Next time it happens do try double tap AND immediate swipe to see launch icons.
Also try now changing to another clock face, remove the original one and reinstall it if you prefer that one. This is just in case the version installed is corrupted in some way which causes the issue to reappear sporadically.
Best Answer02-18-2022 06:23
02-18-2022 06:23
