08-12-2022 12:11
08-12-2022 12:11
The touchscreen of my Versa 2 has stopped working properly since this week. In the training app, the finish flag no longer works to end a training.
I have the impression that the top right part of the touchscreen no longer works.
Does anyone have an idea if/how this can be fixed?
I have already done a factory reset.
Thank you very much for your responses.
08-18-2022 11:00
08-18-2022 11:00
Meanwhile, my Versa 2 no longer works at all!
Only the side button still works, the screen is unresponsive and my Versa is not syncing with my cell phone.
Best Answer08-18-2022 11:39
08-18-2022 11:39
I think you have to press the side button for 9 seconds or something like that.
Seems that worked for me a few times. It might reboot the Fitbit.
Good luck.
Best Answer08-18-2022 11:56
08-18-2022 11:56
Thank you for your answer.
I tried that a few times, then my Versa 2 worked for a while and then it stuck again.
