11-19-2019 02:10
11-19-2019 02:10
My Versa 2 is very unresponsive. Also, it constantly "hangs" and reboots itself sponstaneously. For example, it literally takes me 10 minutes to turn an alarm on and then put it into sleep mode before I go to bed. Any suggestions?
11-19-2019 07:26
11-19-2019 07:26
If you can. try a Factory Reset by swiping left to Settings, then About, and then Factory Reset.
Best Answer11-19-2019 10:09
11-19-2019 10:09
Mine is doing the same except it’s frozen and i can’t even swipe to the left to reset. It’s stuck in do not disturb mode. HELP
Best Answer11-19-2019 10:31
11-19-2019 10:31
Contact Customer Support.
