05-31-2021 14:03
05-31-2021 14:03
My versa vibrates every Sunday midnight. How can I stop this?
05-31-2021 17:20
05-31-2021 17:20
Welcome to the Fitbit Community, @Deva2.
Thank you for the information provided.
I noticed that you've been in touch with Customer Support. I'm pretty sure they've done their best to provide a high level of support. If after following their instructions you continue experiencing the same problem, please let them know in order to get further assistance.
See you around.
Best Answer05-31-2021 17:25
05-31-2021 17:25
Sounds like you might have a silent alarms set for then. Also check phone calendar to make sure you don't have an alarm or reminder set for then.
If you have set any alarms up via Alexa, they are stored separately.
Best Answer05-31-2021 22:26
05-31-2021
23:56
09:22
DavideFitbit
05-31-2021
23:56
09:22
DavideFitbit
Yes, I think that’s what’s on mine too! How can you turn it off?
Thanks, I had a look & no alarms set. It wakes me up but I vaguely think I remember seeing about the 150 min active goal
Best Answer06-01-2021 00:50
06-01-2021 00:50
If zone minutes for week as @MarkMM suggested, try on Versa 2 itself, Settings > Active Zone Minutes; says 'Get reminders to hit weekly goal' which doesn't sound quite like it but worth trying.
06-01-2021 02:16
06-01-2021 02:16
Best Answer06-02-2021 09:22
06-02-2021 09:22
Hi, thank you for your reply @MarkMM, and welcome to the Community forums, @Deva2.
Thank you for sharing this inquiry about your Versa 2 watch.
Since you only get this notification or alarm every Sunday, please let me know if you're able to turn it off after the steps @JohnnyRow mentioned earlier, or if you're still receiving the notification.
I'll be around.
