01-31-2020 03:48
01-31-2020 03:48
So, I bought my Fitbit Versa 2 less than a month ago and its updated and all that. Now I'm having this problem that my device won't stay in wifi connection more than a minute and because of that I can't download my deezer playlists anymore. I have already tried shutting down the device, forgetting the same wifi and connecting again... Is there anything that would help?
01-31-2020 12:09
01-31-2020 12:09
Try a Restart and do it several times if necessary. That's different than just shutting down.
Best Answer02-01-2020 05:39
02-01-2020 05:39
Thank you for the tip, but it doesn't worked:( I have done it now several times yesterday and today...
Best Answer02-01-2020 07:36
02-01-2020 07:36
Try a Factory Reset by swiping left to Settings and then About, Factory Reset.
Best Answer02-01-2020 10:55
02-01-2020 10:55
Thank you again, I did that also while ago, and the same issue is back:( Really annoying...
Best Answer02-01-2020 12:06
02-01-2020 12:06
Contact Customer Support.
