Versa 2 will not reset or sync
Hi, My unit is no longer operating correctly, related to the many cases already documented. Is there a replacement program so I can get a new one.
Model: Fitbit Versa 2
Problem: Unit does not execute the reset function correctly; stuck in a loop saying data not cleared.
Thank you,
MIke
Moderator edit: format.
2 REPLIES 2
Hi @Netgainx - have you tried this
Make a note of the names of any clocks or apps you use or settings you have made, then
Remove any entry for the watch from the phone's Bluetooth and
In the phone Fitbit App
Click on profile photo [top left]
If the device is still showing remove
[by dustbin top right]
Click on  + Set up a Device
Follow the installation instructions
Welcome to the Fitbit Community, @Netgainx. I'm sorry to hear about the message you get on your Versa 2.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
