03-01-2022
14:26
10:24
AndreaFitbit
03-01-2022
14:26
10:24
AndreaFitbit
My versa will not turn on. Says data not cleared sync and try again.
03-02-2022 10:32
03-02-2022 10:32
Welcome to the Fitbit Community, @Ppollard. Thank you for reporting the message that appears on your Versa 2.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
