03-20-2023
15:35
09:14
03-20-2023
15:35
09:14
Hello...my Versa 2 charger doesn't seem to charge. I have made sure it is facing to correct way ion the cradle but it doesn't seem to be responsive. Any suggestions on what I can do? Thanks.
03-22-2023 09:17 - edited 06-19-2023 06:39
Hi there, @Callyo. Thanks for stopping by in the forums and sharing the details about the issue with your Versa 2.
In addition to the tips and recommendations provided by @MakMak, please see Why isn't my Fitbit device's battery charging?
Best Answer03-22-2023 07:12
03-22-2023 07:12
Hi, @Callyo! Have you tried plugging it into another outlet/brick to make sure the issue is with the Fitbit hardware? Also make sure the contacts are clean on both. Finally, have you checked that the pins are still popped out on the charger? That seems to be a common failure.
MakMak | Community Council
Best Answer03-22-2023 09:17 - edited 06-19-2023 06:39
