07-03-2020
17:19
06:13
07-03-2020
17:19
06:13
My versa is not even that old and is well within warranty. Now I am having issues with it turning on and it cant even do basic tasks! Its literally fully dead and I cannot press any of the button combinations to get anything to work.
Can someone give some insight as this is quite frustrating. Thanks.
07-04-2020 06:15 - edited 01-31-2024 08:03
Hi there @PeachyP, welcome to the Community Forums. I'm sorry to hear about your Versa 2's recent behavior. Thanks for the details provided in your post, I'll be glad to help you.
As per the description of your post it seems that the battery of your Fitbit may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Hope this helps you to get back on track. Let me know if you need further assistance.
Best Answer07-04-2020 13:35
07-04-2020 13:35
Thank you. I still do not see it charging still. Is there a way to video it to you? Please help me out, thank you..
Best Answer07-06-2020 04:34 - edited 10-12-2023 03:00
Hi there @PeachyP. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
