01-04-2020 07:51
01-04-2020 07:51
I have been unable to use my new Versa 2 because it is stuck on loading.
01-04-2020 08:09
01-04-2020 08:09
Hi @JMdavis , could you be so kind to be a bit more specific what you exactly mean? regards kuzibri
Best Answer01-04-2020 08:16
01-04-2020 08:16
Best Answer01-04-2020 08:20
01-04-2020 08:20
Hi @JMdavis , reset your Versa 2 by long pressing the left button untill you see the Fitbit logo and release the button. You may have to do that several times in a row. Regards kuzibri
Best Answer01-04-2020 08:26
01-04-2020 08:26
Best Answer01-04-2020 08:29
01-04-2020 08:29
Hi @JMdavis , since your Versa 2 is brand new and thus under warranty, contact Customer Support asap. Regards kuzibri
