10-20-2020
07:15
09:24
10-20-2020
07:15
09:24
Hello,
I tried updating my Fitbit and it froze and won’t sync with my phone/app anymore. It’s been like this for a day. Any idea how to fix this?
Thanks!
10-20-2020 09:27 - edited 04-21-2024 08:18
Hi there @Swinther, welcome to the Community Forums. I'm sorry to hear about your Versa 2's recent behavior after trying to update it, I understand where your concern is coming from. I'll be glad to help you.
If you haven't done so yet, please restart your Versa 2 by following these steps: How do I restart my Fitbit device?
If the restart doesn't work I'd like to ask if when you performed the restart on your watch you felt a vibration? If your watch did not vibrate, please try the steps below:
Best Answer10-20-2020 09:27 - edited 04-21-2024 08:18
Best Answer10-22-2020 05:32
10-22-2020 05:32
Hey,
unfortunately that didn’t work.
Best Answer10-22-2020 05:51 - edited 09-25-2023 05:34
I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
