Versa 2 won't sync
ANSWERED
I need to turn off my versa 2 in order to get it to sinc.
1 BEST ANSWER
Accepted Solutions
Hi there, @Crosthwaite5. Welcome to the Community Forums.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If you continue having issues, please see Why won't my Fitbit device sync?
Hope that helps.
2 REPLIES 2
Hi @Crosthwaite5  - this shouldn't be necessary if the phone is setup properly though you may also need to restart your phone if you have a problem syncing.
The cause of why it stops syncing needs investigation. Possibly a battery saving setting on your phone for the Fitbit App or Bluetooth.
Hope that helps.
