07-15-2022
06:04
07:32
07-15-2022
06:04
07:32
For the last week, I have experienced issues syncing my versa 2. Initially, I was able to resolve the issue by putting my versa 2 on the charger (although the watch was already fully charged). However, this will no longer remedy the issue. I have turned the bluetooth off and on, restarted my phone, cleared the cache and data on the app, and eventually uninstalled and reinstalled the app. All with no success. Any guidance is gratefully received.
Hi there, @Niamhdev. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
@Niamhdev Awesome! I'm glad to hear that the issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
