09-13-2022
14:45
07:46
09-13-2022
14:45
07:46
My fitbit wo t sync to my phone I, have uninstall and reinstalled, I have logged out changed password. It won't do it. Please help!!
09-14-2022 07:49 - edited 08-18-2023 05:43
Hi there, @Cazzadulake. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
As @SunsetRunner has suggested, please try the following steps:
f the issue persists, please see Why won't my Fitbit device sync?
09-13-2022 15:34
09-13-2022 15:34
Hello @Cazzadulake
Try logging out of the Fitbit App, turn your Bluetooth off, restart your phone then turn your Bluetooth back on again. Log back into the Fitbit App and try and sync.
If the problem continues try restarting your Versa 2. just press and hold down the Versa 2 on the side of the Versa 2 until you see the Fitbit Logo then release the button. You should feel the Versa 2 vibrate telling you the restart is done.
If toggling the Bluetooth or restarting doesn’t help you can always try settings it up as a new device again. You won’t lose any of your data if you set it back up. But you will however lose any data you may have accumulated after your last successful sync.
Here is how you set up your Versa 2 again as a new device. Please follow these instructions carefully and do not skip a step:
😃 I hope this provides you an answer and gets your Versa 2 syncing again. Please let me know.
