03-04-2024
07:52
05:17
03-04-2024
07:52
05:17
Suddenly this morning my Fitbit Versa is not syncing (I’ve tried syncing multiple times) and is not connecting to Bluetooth. The only thing that’s updating, for some odd reason, is calories burnt. When I plug in the watch it’s 90% charged but the app is stuck on 48%. When I try to sync it doesn’t update. Help!!
Hi there, @Gmakhlo. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still not syncing. I will do my best to help you with this!
As a first approach, I suggest following the troubleshooting steps provided in this help article Why won't my Fitbit device sync?
If the issue persists, please try the steps below in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Regarding the calories burned you seen on the Fitbit app, please note this is an expected behavior as that value is your estimated calorie burn for the day so far based on your BMR. We estimate your calorie burn based on your age, gender, height and weight. You burning calories even when you are sleeping. When you are not wearing your Fitbit then it is estimated your passive calories burned. For more information, see How accurate are Fitbit devices?
