03-27-2023
15:20
07:00
03-27-2023
15:20
07:00
03-28-2023 07:01 - edited 06-19-2023 05:37
Hi there, @Daviest254. Welcome to the Fitbit Community Forums.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
