01-23-2020 19:57 - last edited on 01-24-2020 12:00 by LiliyaFitbit
I purchased a Used Fitbit Versa 2, that needs unlocked by phone. I have no way of getting a hold of seller for assistance. Is there anyway to hard reset the watch so that I can connect to my phone?
01-24-2020
12:00
08:50
01-24-2020
12:00
08:50
Welcome to the Fitbit Community, @Greale36.
Thank you for sharing that the Versa 2 you purchased needs to be unlocked by phone. Since you're unable to do that, I recommend doing a factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
01-24-2020
12:00
08:50
01-24-2020
12:00
08:50
04-02-2020 00:03
04-02-2020 00:03
Help, I’ve tried this and now my watch says ‘data not cleared sync and try again’ with a Red Cross. I can’t sync because it’s no longer connected to my phone!
04-02-2020 02:27 - edited 04-02-2020 02:27
If you get a Red Cross on a tomtom, that the memory module is broken and he's not more bearable, suspect that this is the case with the fittit a Red Cross.
Hopefully guarantee...
04-19-2020 15:40
04-19-2020 15:40
Hi, I have the same issue with the Red Cross on the screen. How can I fix the issue so I can use my Fitbit I just purchased?
04-20-2020 03:10
04-20-2020 03:10
As I wrote when you get a Red Cross, it often shows that memory is broken and no longer works.
So presumably dead is
04-20-2020 03:34
04-20-2020 03:34
You just need to delete all Bluetooth connections to the device. Reset your app and you can get it to work again. Mine works perfectly now.
04-22-2020 18:07
04-22-2020 18:07
Hi, I have a versa 2 that has a locked screen that needs to be unlocked with a phone. Whilst trying to fix, I have deleted from my phone and need to read it, but can’t as I can’t see the verification code on screen because of the locked screen. I have tried a factory and hard reset but not working
05-12-2020 21:42
05-12-2020 21:42
Hi Mon35,
I have the same problem. Were you able to find a solution?
Thanks,
Alejandro.
06-14-2020 20:08
06-14-2020 20:08
Hi!
I'm facing the same problem. Have yours been resolved?
06-15-2020 12:19 - last edited on 06-15-2020 15:22 by LiliyaFitbit
Hi, Yes I had to do the factory reset steps and that did it for me. My
device has been working as usual for about 2-3 weeks.
Thank you,
*es buen ejercicio acostumbrarse a la *
*compañía **de la gente sencilla pues tanto la humildad como la soberbia se
transmiten a menudo por simple contacto.*
06-16-2020 10:28
06-16-2020 10:28
Hi I have tried suggested does not work. I have the unlock with phone on screen no fitbit logo shows until I have shut the watch down please help
07-21-2020 00:08
07-21-2020 00:08
I’ve just done the same thing. Have you got it fixed. Seriously can’t get it sorted
07-21-2020 00:17
07-21-2020 00:17
07-21-2020 00:53
07-21-2020 00:53
Hi Friends,
I decided to contact the Fitbit support team and have them guide me through the reset process. Despite many attempts, my device still fail to restart as I cannot access it without keying in the 4-digit code.
The customer support officer deemed that the device is faulty and has kindly arranged for a 1-1 replacement - which I’ve received.
You may want to do the same and get in touch with their support team to see how best they can assist you.
Good luck! ☺️
07-21-2020 00:56 - last edited on 07-22-2020 14:30 by LiliyaFitbit
Thanks for the advice. All sorted just took loads of time.
07-21-2020 00:58
07-21-2020 08:19
07-21-2020 08:19
09-05-2020 06:29
09-05-2020 06:29
Thank you so much! I finally unlocked my Versa 2 with the steps in your reply.
11-01-2020 04:58
11-01-2020 04:58
How long did you have to hold it for?
