08-31-2022
13:10
14:36
08-31-2022
13:10
14:36
So I have charged my watch and it hasn't came on for days , any ideas please
09-01-2022 14:46 - edited 07-15-2023 05:04
Hi there, @Kazza1135. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. @Guy_ Thanks for helping out!
As a first approach, I'd recommend restarting your Versa 2 as suggested here How do I restart my Fitbit device?
If the restart doesn't work and your Fitbit device does not vibrate while performing the restart, I suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Best Answer08-31-2022 20:53
08-31-2022 20:53
Hi @Kazza1135 - it is most likely not charging but to make sure hold the button for 10 seconds.
This link may help if the watch hasn't got wet How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer09-01-2022 14:46 - edited 07-15-2023 05:04
