02-07-2024
08:30
08:41
02-07-2024
08:30
08:41
Versa 2 won't update to my new time zone.
02-07-2024 08:47
02-07-2024 08:47
Hi there, @RonJell5. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, I will be glad to help you to update the time on your Versa 2.
As a first approach, please note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
Best Answer02-07-2024 09:25
02-07-2024 09:25
Best Answer02-07-2024 09:44
02-07-2024 09:44
@RonJell5 Awesome! I'm pleased to hear that the steps recommended did the trick!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
