06-28-2022 11:47
06-28-2022 11:47
I would like to set up my weather app. I went into my device page to select Apps as I have seen in numerous YouTube demos but my versa does not have Apps to select from on the device page. It has Alexa, Gallery,Media,Wallet and How to Use but no Apps!
06-28-2022 12:12 - edited 06-28-2022 13:29
Hello @Zellmo
Try this route. Open your Fitbit App, tap your profile picture then scroll down and tap Versa 2. Now tap gallery. Now scroll down until you see weather and tap that. Here you can adjust your settings and permissions.  Make sure all your permissions are enabled and under settings is where you can put Fahrenheit or Celsius as your preferred unit. After you completed the the set up then make sure you sync the Versa 2 to accept any changes you made.
😃Please let me know if this provided you the best answer to your question. Keep me updated on how it goes
Hello @Zellmo
06-28-2022 13:08
06-28-2022 13:08
06-28-2022 13:11
06-28-2022 13:11
Dear MegaBite, You nailed it! I am shocked that I could find someone to solve this mystery for me so fast. Thank you, thank you, thank you. You are Awesome!
06-28-2022 13:27
06-28-2022 13:27
Your so very welcome @Zellmo!😃 I hope you enjoy the rest of your day and as always Happy Stepping!
