09-29-2022
21:24
11:13
09-29-2022
21:24
11:13
Hi @mrc48 - searching in the Gallery is going to be a problem because nearly all clock faces will do that.
You probably have to just look or add some other criteria. You may not find what you are looking for as most will be more sophisticated.
SimpleAnalog has just time for 3 seconds then other stats pop-up.
You could always write your own, it's quite simple, with Fitbit Studio that way you can change the way it looks to suit your needs, it may be quicker to do that. The sample clock is pretty much a clock and you only need add steps.
Best AnswerHello
I should have stated my issue more clearly. I have found a number of clock faces that show just the time and steps, however, I cannot find one where the step count is large and easy to read. I am seeking a clock face with a large time readout and a large step readout. I will checkout the Fitbit studio, if I can find it and figure out how to use it.
Thanks
