10-04-2022
07:20
17:09
10-04-2022
07:20
17:09
The button on the side of Versa 3 is stuck. I've tried a toothpick, rubbing alcohol, air, squeezing the sides and nothing works. Does anyone have other suggestions? Thank you!
10-04-2022 07:45
10-04-2022 07:45
The Versa 3 does not have a true "button" that pushes in and out, so there is nothing to get "stuck". It is just a "haptic" touch-sensitve area.
Best Answer10-04-2022 08:02
10-04-2022 08:02
Well, whatever it is, it is in fact stuck and I am unable to press it to turn on my fitbit. It doesn't turn on when I tap the screen either.
10-04-2022 08:19 - edited 03-15-2024 06:39
Hi there, @Acarlton311. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before posting here. @JohnnyRow Thanks for the clarification.
As a first approach, please make sure that your Versa 3 is fully charged. For more information, see How do I charge my Fitbit device? and/or Why isn't my Fitbit device's battery charging?
Please try placing both forefinger and thumb each side of face and pressing gently, also make sure to cover the entire button with your finger. For more information, see How do I navigate my Fitbit device?
If the above doesn't work, please try restarting your watch as instructed here.
Best Answer10-04-2022 08:44
10-04-2022 08:44
@Acarlton311 wrote:Well, whatever it is, it is in fact stuck and I am unable to press it to turn on my fitbit. It doesn't turn on when I tap the screen either.
So basically what you saying your problem is that you can't turn on your screen.
10:02
10:21
10-04-2022
10:02
10:21
Hi @MarreFitbit. Thank you for your assistance. I have tried what you suggested and the screen will not turn on. My finger covered the button completely, but the button is depressed and will not reposition itself. It's less than a year old, I've never had this happen before. Is there anything else I can do?
Update: Yes, it's not doing anything.
Best Answer10-04-2022 10:30 - edited 07-31-2023 10:40
@Acarlton311 I appreciate you had followed the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 🙂
