09-13-2023 13:29
09-13-2023 13:29
My Versa 3 was behaving badly (screen not coming on, for example) so I restarted it by holding the button for 10 seconds. The restart got as far as the logo but then stopped. It seems to be stuck on the logo or in a restart loop. I looked through the forums and various links I found on Google and have not found a solution that works. The watch was working perfectly fine just a few hours ago. Any suggestions?
09-13-2023 15:04
09-13-2023 15:04
It's good to see you back in the community @golddave.
Thanks for sharing the details regarding this issue. Thank you, for trying to fix it by your own.
If you haven't done so yet, please try the following steps:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
