12-31-2023 17:10
12-31-2023 17:10
I have a Versa 3 and I planned on using it a while back. Plugged it up to charge, and when I did that the screen cut on, showing the battery bar. Everything seemed normal. I went about my days and forgot about the fitbit charging. It's been at least two months, but now I tried to start the fitbit. It won't respond. I took it off the charger, changed charging locations, held the button for 10 seconds, pressed it three times. Nothing seems to turn it on. Have I permanently screwed this battery? Or is there a fix?
12-31-2023 22:16
12-31-2023 22:16
Hi @Abkamer - maybe it is ok but just not charging, follow these tips How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
