11-23-2021
00:51
20:40
11-23-2021
00:51
20:40
Just bought a new Versa 3 to replace my Charge 2 which died after 2 years. The battery life on the Versa is awful and needs charging every other day. Anyone else with problems?
@EllaViv The Versa 3 normally lasts 4-6 days depending upon options, apps and activities that use GPS. There is a new firmware released recently which seems to be sucking the battery life out of the device (last about 24h only) and many people are reporting issues.
Fitbit don't seem to have understood that there is a serious issue yet... thanks for your report because you're not alone !
Hi there, @EllaViv. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3.
As @scjsjo has mentioned, your Versa 3 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Best AnswerMost of us haven't had issues until recently. That response is tone deaf to an issue we are all having. Months ago my charge lasted a week. Now with not changes to my tracker it last 2 days at the most.
Hi,
I have contacted customer service a couple of times & did all the necessary steps they advised. Still having the same issues. The last time the Fitbit was working properly was prior to the upgrade on 11/7/21. It's absolutely frustrating! 🤬
Fyi...I will be contacting Fitbit as I charged mine fully this morning before I taught at the gym & it died within 2 hours 🤬🤬
Absolutely ridiculous at this point!! Keep us posted on what you find out please as I will as well.
@Tavo This is the current reply from fitbit chat....
Got it and thanks for providing the case number. We always do our best to improve our Fitbit products and services, and your feedback is a big part of that process.
Okkkkkk. Hopefully we'll hear something soon. I went out this afternoon with a dead fitbit on my wrist, which was working perfectly up until this **ahem** update.
Yes, do it! Best decision I made was returning it.
Boxed up and ready to return. Have ordered the charge 5!
