09-29-2020
07:01
20:52
09-29-2020
07:01
20:52
The "button" to wake the screen is very finicky and doesn't always work, and in trying multiple times I always end up with the long press shortcut opening when I just want to see the time.
Then there is the notifications bar which opens too easily and then swiping to close apps always takes multiple tries 😑
Is there some secret to operating this that I am just not understanding?? 😔
02-07-2023 18:27 - edited 02-07-2023 18:28
Any resolution on this (non functioning button and quick discharge of battery), this has recently started for me.
02-08-2023 04:36
02-08-2023 04:36
03-18-2023 02:29
03-18-2023 02:29
I never had a problem at all with my side sensor ‘button’ until recently, and now, same as you, the side button doesn’t work at all and my battery is discharging in about 48 hours when it used to last approx 6 days.
03-18-2023 02:35
03-18-2023 02:35
And me. I never had a problem with the button before, but now it doesn’t work at all and battery discharging quickly
03-18-2023 18:30
03-18-2023 18:30
03-19-2023 01:07
03-19-2023 01:07
03-19-2023 13:32 - edited 03-19-2023 13:33
Maybe their is oil on the sensor.. Try cleaning with isopropyl alcohol
Have you tried a restart or shutdown?
03-19-2023 17:01
03-19-2023 17:01
any luck on this? I am having the same issue.
03-19-2023 22:44
03-19-2023 22:44
03-19-2023 22:46
03-19-2023 22:46
03-20-2023 04:52
03-20-2023 04:52
03-20-2023 05:00
03-20-2023 05:00
03-20-2023 05:57
03-20-2023 05:57
06-15-2023 13:54
06-15-2023 13:54
This is the description that worked for me. You have to get your skin into the depression or it won't register. So push a bit harder to make sure you get into the indent. The other pinching tips etc didn't work for me. Thanks for the help.
Until I saw this message I wanted to toss my new watch off a roof and I've only had it two days. Worst design ever and the instructions don't help. One video or drawing could sort this out for so many annoyed people
