To @MrClutch and all others under his message.
I copied your sentence of the topic you made a very long time ago.
A week ago, I experienced the exact same problem with the BT connection, it constantly wanted to ‘pair’ again etc. and wanted to throw away my Versa 3 cause in my opinion it was now getting useless. Yesterday I solved the problem and I want to tell you how.
On the Fitbit itself there is by settings a function to put the Fitbit back to fabric settings. I did that. I also turned off my phone and put it on again. From there, I turned on the Fitbit again, Fitbit said to open up the Fitbit app. My Fitbit was not connected anymore to the Fitbit app which was a good thing! Fitbit watch said to open the app, the Fitbit watch gave then a code what I needed to enter in the Fitbit app. From there the app said that the watch needed an update. The Fitbit app communicated that we needed WiFi too for the update and so I selected that too. Then the watch started to update itself, after that it was done. And since then I have no problems anymore with that the Fitbit watch is constantly disconnected from the phone (mine was only connected when I opened the app again, app gave request to connect, I clicked and it was temporarily for 30 sec connected again)
I hope it somehow helps although I would understand you have now probably a totally different smartwatch.
Greetz from the Netherlands! ✌🏻:netherlands:
