12-04-2020
15:28
20:50
12-04-2020
15:28
20:50
I've had the Versa 3 for about 1 hour. The display screen went to Dim and I can't set it to Max. The button setting won't let me change it to motion and button. Help.
12-05-2020 00:28
12-05-2020 00:28
Hi @sunrisenjb, welcome to the community.
The first thing I would try would be a restart. You can do that by pressing and holding the button for 10 seconds (until you see the fitbit logo).
12-05-2020 01:05
12-05-2020 01:05
12-05-2020 02:16
12-05-2020 02:16
Just checking, did the restart fix your issue?
12-05-2020 10:06
12-05-2020 10:06
01-20-2021 14:25
01-20-2021 14:25
@N8teGee thanks for your help. Hi @sunrisenjb welcome back to the Forums.
@sunrisenjb thanks for sharing those details and for the troubleshooting performed. If by any chance you need to restart your Versa 3 you can find the steps to do it in this link How do I restart my Fitbit device?
You can learn more about your device's features in this link How do I get started with Fitbit Versa 3?
See you around.
02-16-2022 10:49
02-16-2022 10:49
I tried the restart. Same issue. Also cannot change any of the settings such as 'button only or button and wrist' or time out, etc.
02-16-2022 10:50
02-16-2022 10:50
The restart does not fix my issue. I have the same problem--display will not change from DIM.
02-16-2022 11:40 - edited 02-16-2022 11:41
02-16-2022 11:53
02-16-2022 11:53
02-16-2022 16:07
02-16-2022 16:07
02-16-2022 16:41
02-16-2022 16:41
