03-02-2021
05:31
20:47
03-02-2021
05:31
20:47
My Versa 3 (paired with OnePlus 6 phone running Android 10) always shows duplicate notifications for WeChat. I searched the community. The duplicate notifications issue has been there for a few years without a solution.
Fitbit needs to look into this. At least, the easiest workaround Fitbit could do is to add one more if-statement in the code to check if a notification is a duplicate of the previous one.
In my case, I only have this issue with WeChat. Other apps seem OK.
03-08-2021 05:22
03-08-2021 05:22
Hi there @deiG. Thanks for sharing the details about the issue with your Versa 3 as well for the image attached.
Is WeChat your default app for text messaging in the Fitbit app? If so, try switching to your phone's messages and see if now you only receive one message from WeChat every time you receive a notifications from that app.
Hope that helps.
Best Answer03-08-2021 05:28
03-08-2021 05:28
@MarreFitbit , no, WeChat is NOT my default app for text messaging in the Fitbit app.
Best Answer03-08-2021 10:28
03-08-2021 10:28
@deiG Thanks for confirming that WeChat is not your default messaging app in the Fitbit app.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer01-31-2022 19:10
01-31-2022 19:10
This issue still remains unresolved
Best Answer02-15-2022 06:25
02-15-2022 06:25
The issue is still there.
