09-06-2022
12:46
17:17
09-06-2022
12:46
17:17
I've had it 3 days and since the beginning it was slow but I thought it was just update lag. Then it would have a mine of its own and only turn on when it wanted and wouldn't respond to when I tapped the side button. If it turned on I couldn't interact with the screen and I restarted it and it worked for an hour. It still vibrates and tracks but I can't use it when I want to.
Hi there, @Thefunkyboi. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
As a first approach, please confirm that you've restarted your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Also, make sure that your have enabled Screen Wake on your Versa 3. For more information, see How do I navigate my Fitbit device?
