11-30-2022
07:10
16:58
11-30-2022
07:10
16:58
I’ve had the Versa 3 since March ‘22, and now it’s not working at all. I’ve tried to reboot, charge, and whatever else; no response. I had the Versa 2 prior to the Versa 3. The Versa 2 lasted about 10 months. I love the battery life so I just upgraded to the Versa 3. These devices are too expensive to continue to buy every 9-10 months. While the Fitbit worked, I loved. I don’t want to go back to the Apple Watch……Help!
12-01-2022 09:20 - edited 08-15-2025 07:08
Hi there, @Marco1906. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. We‘re taking your comments and sentiments in regards to our products and services into consideration.
As a first approach, please restart your Versa 3 by following these steps.
If the above doesn't work and your Fitbit device doesn't vibrate while performing the restart, I suggest trying the following:
Hope that helps.
12-02-2022 13:34
12-02-2022 13:34
Hi Marie. Having the same issue. All was well until we’d morning. Email reminder that battery needing charging. Plugged in the charger. Battery continued to drain. Now dead. No response or activity on screen after leaving on charger overnight.
what’s the next step…Jeff N
Best Answer12-03-2022 00:18
12-03-2022 00:18
HI @Marco1906 , @Skittles2014 - also check this link How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
