10-21-2020
01:18
20:52
10-21-2020
01:18
20:52
I am having some trouble with my Versa 3 accurately tracking and recording my swimming.
Every time before I swim I set the pool length as 20m on the watch. I always double check that it is set as 20m before I start the activity. However, whenever it synchs to the app, the lengths are recorded as 25m. This means that all the stats are incorrect (such as time per 100m and total distance swum).
Can anyone suggest how I could either change the recorded length in the app after it has (incorrectly) synched or alternatively make sure that it synchs with the correct pool length??
10-22-2020 07:51 - edited 11-16-2023 03:01
Hi there @CamillaSalmon, welcome to the Community Forums. I'm sorry to hear that your pool lengths tracked on your Versa 3 are not syncing correctly. I understand where your concern is coming from, I'll be glad to help you.
If you haven't done so yet, I'd recommend taking a look at this help article: How do I track my swims with my Fitbit device?
Inconsistencies in your swim data may be caused by any of the following:
If the issue persists, I'd recommend restarting your Versa 3 by following these steps: How do I restart my Fitbit device?.
Let me know how it goes.
Best Answer10-27-2020 03:31
10-27-2020 03:31
Hi @MarreFitbit. Thank you for your reply. However, it does not really help me solve the particular issue I am facing! I hope you can maybe give me some more insight.
I am swimming between 60 and 100 lengths, which takes at least 30-45 mins, and if I am going to take any breaks I pause the activity. Therefore, I cannot imagine why any of the reasons for inconsistencies outlined above would be the cause of the problem. I have restarted my Versa 3 and it did not help resolve the problem.
I have no problem with getting my Versa 3 to track my swims. And my Versa is recording the correct number of lengths swum. My issue relates to the length of the pool. I know how to set the pool length on the watch. I do this every time before I start a swimming activity - I set the pool length to 20m. However, when I complete the activity and then synch it to the app, it shows the pool length as being 25m.
So my issue relates specifically to how to ensure that the length reflected in the app once the activity is completed is the length I chose before I started the workout (ie. 20m not 25m).
Any information on how to ensure that the length selected is the length reflected in the app would be appreciated.
Thank you
Best Answer11-01-2020 04:37
11-01-2020 04:37
I’m also having this problem and I think it must be a glitch with the Versa 3. I’m trying to change my pool length to 33m every time and, like you say, it doesn’t seem to stick when recording the swim as afterwards it shows stats for a 25m pool swim.
I’ve been correcting my distance in the app afterwards so that it matches up with the actual distance I swam but it is a pain. Seems hardly worth using the Fitbit for swimming until this gets fixed.
11-03-2020 23:59
11-03-2020 23:59
Hi @emmaprew ! Thanks so much for your reply - I am relieved I am not the only person facing this problem!
Can you tell me how you change the distance in the app?
Best Answer11-04-2020 01:23
11-04-2020 01:23
No worries. You selected the swim in Exercise and then click the three dots in the top right and Edit Exercise Detail to be able to change the distance.
Best Answer11-04-2020 01:26
11-04-2020 01:26
Ah great thanks I'll see if that works for me - in the past I think it has only given me the option to delete the activity rather than edit it! But hopefully I can figure it out.
Best Answer12-07-2020 21:00
12-07-2020 21:00
With versa 2 you set the laps once and it stays. With the Versa 3, I swim in a 50 metre pool always, and every time I set it at poolside it still records 25 metres. I forget later to edit because I have other things happening in my life. Today it recorded a swim and gave me a map, no laps, no metres. Aaagghhh
Best Answer12-07-2020 22:07
12-07-2020 22:07
An update came up for my versa 3 a few weeks ago and that seems to have fixed the issue now.
01-12-2021 16:18
01-12-2021 16:18
I have the same problem. I have set the length to 50 m but it gives me stats for a 25 m pool. Hence it thinks I have swam twice as far. Clicking the 3 dots in the top right only gives me the option of deleting. There is no option to edit exercise detail.
10-12-2021 01:16
10-12-2021 01:16
I’m now having the same issue. It was fine when the pool was actually 25m but since lockdown measures ended at my centre and the pool has gone back to 50m, for every 50m length I do it calculates 2 lengths but then multiplies that by 50m because that’s what the pool length is set at in my watch. In other words it will correctly tell me I’ve done 25 lengths but somehow counts it as 50 and multiplies that by 50 to tell me I’ve swum a distance of 2,500 not 1,250. I swim for 45 minutes straight. No stops. Only one type of stroke etc plus I manually start the tracker as it never auto detects. Any ideas?
Best Answer01-09-2022 19:41
01-09-2022 19:41
Hi I have this exact same issue. Has anyone found a solution to this? I swim in a 50m pool and set that distance on my watch. However, when I swim, it double counts my laps for some reason and so, I end up swimming 3000m in 1h. For a min I was super happy when I first saw it thinking I've somehow improved drastically lol. Hope someone can help!
06-26-2022 06:47
06-26-2022 06:47
I just had this same problem yesterday. I set my watch for a 50-meter pool, and it doubled my total lengths and swim distance.
