05-15-2022 02:41 - last edited on 12-18-2022 19:58 by
Is there an app for versa 3 that allows you to type a short text right from the watch? Versa 2 had one but haven't seen one for the 3. I'm not talking about adding a note from the app on the phone I'm talking about directly on the watch
05-15-2022 04:44
05-15-2022 04:44
@Jdod7674 Please search the Gallery from your mobile app to find apps specific for your device. Tap on your profile picture > your Versa 3 image > Gallery icon > slide the toggle to Apps > use the search feature. The web Gallery doesn't filter by device, so searching is difficult. If you can remember the name of the app that you had on the V2, you can use the web Gallery to find the developer. Maybe the developer can make a V3/Sense version.
Laurie | Maryland
05-15-2022
20:44
10:18
05-15-2022
20:44
10:18
Hi @Jdod7674 - if you do a Google search in gallery.fitbit.com for "note" it returns 111 apps.
May be one of those was for a Versa 2 and may be there is one for the Versa 3.
Doing a Google search allows you to see all Apps available for all watches, so can be useful if you don't remember the name of an app on an older watch.
