09-24-2023
09:06
04:35
09-24-2023
09:06
04:35
Hi,
Help. My screen has detached and is just attached by the cables .
Looks like the adhesive has failed.
What do I do?
Hi @DeEmerald
If you are still within your warranty then contact Fitbit customer support (here).
If you you are outside of your warranty I would still suggest contacting customer support first. Otherwise you may be able to reattach it with some glue or adhesive (it will probably no longer be water resistant).
Hi there, @DeEmerald. Welcome to the Fitbit Community Forums. I'm sorry to hear about your Versa 3 screen damage.
I've seen you've followed @N8teGee's advice and contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Best AnswerThanks. Yes no help from FitBit as it’s out of warranty. I still have some months of premium which is pretty much useless now.
I will try some adhesive myself. Can’t be any worse than the previous glue.
I don’t live in a hot country or swim so hopefully it will hold.
thanks
