08-10-2023
17:24
04:40
08-10-2023
17:24
04:40
My Fitbit is less than 12 months old. It has suddenly gone to a half green screen or grey vertical lines. Have fully charged and forced a reboot with no success. Very disappointed
08-10-2023 20:29
08-10-2023 20:29
Mine is about 2 years old, was working fine until about half way through the morning. Was frozen on a message, it finally cleared now I have blue,black, and yellow across the screen
Best Answer08-11-2023 04:42
08-11-2023 04:42
Hi there, @Susieled @Cmajor87. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit devices before reaching out. I understand how you guys must be feeling.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer08-11-2023 15:16
08-11-2023 15:16
