03-10-2025
04:48
07:53
03-10-2025
04:48
07:53
I've searched the forum and elsewhere, tried changing time zone, force stopping app, turning bluetooth on and off and multiple restarts of phone and watch all with no improvement.
A few days ago my watch started showing a time a few hours behind, not a whole number of hours like it has the wrong timezone (for example actual time is 11:46, watch says its 9:59). The app sometimes states sync failed, but normally tells me synced successfully, steps are wrong but sleep is correct in the app. It does take a long time to sync. I have no other fitbit devices in the house and the watch is only connected to my phone.
Changing timezone in the app has no effect on the time, even when watch states sync successful.
Does anyone have any other suggestions please?
03-10-2025 05:25
03-10-2025 05:25
Hi @Penny02 - there was a daylight savings change in America on Sunday which can be problematic.
If you are not affected by a daylight savings change and/or the problem persists on Monday, your watch is probably not fully syncing after you changed the time zone in the Fitbit App settings [not elsewhere].
To make sure, in the Fitbit App, click on the gear, then Date, time & units, Time zone, unselect set automatically, choose a time zone different than yours by at least 2 hours, then sync your watch manually. [If necessary restart the watch].
When the watch time has changed time reverse the process and sync again.
Note if your watch is often on an odd time [like it loses minutes quickly] it could indicate a problem, and to be sure it is not the clock face itself try another one.
03-10-2025 08:38
03-10-2025 08:38
Thanks Guy, we're not in the US and this issue started a few days ago before their DST change. I've set the timezone to one a few hours away from ours, no difference noticed even after multiple restarts. The odd thing is that the time is not out by hours (as in the minutes are correct and hour wrong) but is out by a random amount.
Good suggestion on watch face, I'll try that.
Best Answer03-10-2025 08:48
03-10-2025 08:48
@Penny02- thanks, it is certainly odd. Also you can try swipe up to get into Weather and drill down to see what it says when it lasts synced. It might say something odd, rather than a few minutes ago.
Lastly and unlikely, check your phone is on the correct time, as it syncs with that.
09:43
20:40
ManuFitbit
03-11-2025
09:43
20:40
ManuFitbit
@Guy_ thanks, yes very odd. I don't normally have the weather on my watch, turned on the widget for hourly updates and no data - sync just fails from the phone app now. Steps, calories and heart all being sent from watch to phone. Changing watch face and time zone makes no difference and sync never fully syncs.
Time to contact the support team I think.
@Guy_ cracked it! Removed app (again) and unpaired watch. Reinstalled the app and it detected the watch, went through all the steps and still failed. So added another device in the app, which of course removed the existing device. Went through the steps for this (twice as the first time it failed) and now it all works. So all I can assume is something in the bluetooth connection or within the app was corrupted and wasn't reinstalling.
Best Answer03-11-2025 11:45
