02-20-2022
02:15
20:24
02-20-2022
02:15
20:24
Hi there, my Fitbit Versa 3 won’t turn on - it is stuck on the logo screen. I have tried to turn it off and on… and also charged it but it still shows up with the logo. Please could someone help me. Thank you. Hannah
02-21-2022 03:19 - edited 10-24-2023 04:28
Hi there, @Hannah_FA1. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
In addition to the steps you've done so far, I'd recommend trying the following:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Best Answer02-21-2022 03:19 - edited 10-24-2023 04:28
Hope this helps.
