04-03-2022
17:15
20:14
04-03-2022
17:15
20:14
My versa 3 will not go off of the Fitbit logo. I have restarted it on multiple occasions and just had to order the new sense. Please tell me how I can fix my 3 so I can sell it or something. Thank you.
04-04-2022 05:54 - edited 12-11-2023 04:03
Hi there, @PayMIL. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
It seems like you performed a factory reset while trying to restart your Versa 3, that would explain why it's only flashing the Fitbit logo.
With that being said, please follow the steps below:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer04-03-2022 23:38
04-03-2022 23:38
Hi @PayMIL - Probably best to contact Fitbit Support directly. They may be able to help you to check if it is faulty.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
If it is still under warranty, 1 or 2 years depending on country law, and found faulty it may be better to take it to the shop for a new replacement, rather than accepting a refurbished replacement from Fitbit and dealing with sometimes drawn out return and shipping issues that may occur.
Best Answer04-04-2022 05:54 - edited 12-11-2023 04:03
Hope that helps.
